unsolved Dxf2Gcode Debian BookWorm
melhima
Hi,
I had downloaded the source file from sourceforge.
Did :
sudo git clone git://git.code.sf.net/p/dxf2gcode/sourcecode dxf2gcode-sourcecode
then go to the source folder and try to run the dxf2gcode with
sudo python3 ./make_tr.py
sudo python3 ./make_py_uic.py
sudo python3 ./st-setup.py build
and then
sudo python3 dxf2gcode.py
The infercace start correctly and I can load a dxf file.
The problem come when i try to generate the gcode file
The interface crash and then I get this error
I use debian Bookworm and Python3
I was using the same source with debian Wheezy without any problem
Do you have any idea?
Thanks for your help
Hi, which version of python do you use? This may be in conjunction with a newer python version which is more picky with data types? See link below, seems to be a similar issue with python version ...
